Ok, so i ran your program thru a script i wrote a while ago to check the accuracy of arcs ( as i say we have had this problem occur at work ) The output is below.
As I suspected the warnings you are getting is when an arc start, end and center point are not perfect.
Just note the “N” numbers for each error below. They are the same as the Location numbers in your warning screen from above (except for line N65 - which was the worst deviation of them all - strange).
Since the file still ran fine then i think that means the 1F controller is set to tolerate deviations greater than .003 inch on arcs. So it is nothing to worry about unless you want to do super accurate work.
I will test some more tomorrow on my machine.
tclsh check.tcl -test “arc test.nc”
N12 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
Deviation: 0.0001 0.0007
N15 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
Deviation: 0.001 0.0
N19 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
N22 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
N26 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
N29 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
N33 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
N36 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
N40 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
N43 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
N47 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
N50 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
N54 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
N57 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
N61 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
N64 G2 X-1.499 Y0.104 I0.000 J1.523
0.001 1.523
N65 G2 X-1.489 Y0.281 I1.523 J-0.000
1.523 0.0027
Deviation: 0.0 0.0027
N66 G2 X0.023 Y1.627 I1.512 J-0.177
1.5121 -0.1763
There were 18 instances over or equal to deviation of .0001
There were 18 instances over or equal to deviation limit of .0005
The maximum deviation was 0.0027
Done.
