Hi,
I have a couple questions and was hoping someone here could help out. I’m setting up my first cut, it’s nothing special just some numbers on a board. I’m using carveco and saved my tool paths with the Onefinity BB inch .ngc file format. After uploading it to my controller I got a warning message that 8 of the Arc radiuses differ, by various thousandths of mm, I’m not machining and precision tools so I’m not too worried about that. I am more concerned that the preview to the right has the tool path going to the right of where I designed it to go in carveco, much more the the warnings have given me. Now finally to my question, is this preview accurate, or is this something that is common and most people just hit run anyway? If this is uncommon is there something I can do to fix this? Is there a different file type I can use? Does anyone else have trouble with the .ngc file? I am running a foreman pro, I assume I shouldn’t be saving under the elite .nc option. Any help with this would be greatly appreciated. Thank you.
The preview only shows the boundaries of the vector, not the material.
Thank you for that, I thought it might be cutting off the workpiece.
