I am cutting foam for a packaging project it has 6 different tool paths in vectrics vcarve pro. I clicked array copy and recalculate, and in 2d view it shows the lines/vectors as copied, but when I go to 3d view and preview all toolpaths it shows just the original project down in the corner and nothing else. Am I missing a step?
Drag a box around all vectors, then calculate toolpath.
See if that makes a difference
nope when i copy it then go to toolpaths and recalculate then go to 3d view the copy disappears and when i click on preview all toolpaths i only get one copy the original one array copy seems a bit useless if i have to redo each vector 15 times anyway. update OOOPs. there is an array copy toolpaths button you can hit !!! I just found it. My bad as is per usual. thanks to all also as usual.
