If anyone is using the asus touchscreen minoitor that is compatible with the 1F, would you please tell me how managed to get the touch portion working. The monitor doesn’t have a usb C port for the cable to enable touch. Thanks…
What model number are your looking at?
It is the asus VT229H
I believe you need to swap in a USB 2.0 to USB 2.0 cable to use it, the one that ships with the Onefinity is USB 2.0 to USB C
The monitor has the usb - b connector ( the square block ). So i assume i need a usb-b to c cable then?
On the Onefinity controller end (Raspberry PI) it should be a USB 2.0 type A connector, not USB-C
Yes, i’m sorry you are correct. Thank you.
