Wimaxit 15.6 touchscreen - no touch-
Anyone using the Wimaxit 15.6 touchscreen monito? What is the secret to getting the touch to work? I have the USB C port labelled “Power” going to ac power and the HDMI connected to the Onefinity HDMI controller. The other USB C port on the monitor is connected to one of the USB ports on the controller. I thought that was all you needed, but guess I’m missing something. I do have video, just no touch. This monitor is one of the ones listed by Onefinity as compatible.
Thanks for any help you can provide
I figured it out. Turns out the USB C cable I was using to go from monitor to controller was a charging only cable. I swapped out another cable and the touch screen is working now!
Glad you got it working. How has this monitor been working for you? Any issues?
Mostly good. The screen flickers when the temp in my garage is below 50 degrees which is a little annoying.
The issue I’m having with this monitor. The front screen works good when touching it. But when I go into files. And try to touch on a file it touches another spot on the screen. Anybody have that problem.
