When I have Dry Run Mode enabled and try to execute a job with the Easy ATC, I get an error “ATC IR beam obstructed. Clear and re-attempt on cycle start.”, which appears to be from the RC’s 601.nc.
If I disable Dry Run mode the error goes away, but then I can’t use Dry Run. Is there a way to get them to work together?
I believe Don from RapidChange said that Masso Dry run did not work with his implementation - I may have read this on his Discord, but you could reach out and ask him what his testing showed.
I am not sure if ith works with Masso’s own RapidChange logic, but that would be best asked on their forum.
There pros and cons to using the subroutines vs Masso 5.10 native support, but my personal preference is to use the native Masso support for RapidChange. Being able to use dry run is one of several advantages.
