Greetings Elite Owners,
Before the plethora of releases, I had started down the path of a bit setter and was almost complete, when the new additions appeared. So, I will release my connections and work for the masses to have, please find a link to the Amazon switch I used (currently $9.95) and below is the STL file for the 3D printed housing to mount to your wasteboard. It can also be found on Tinkercad (public) under the name “Zero Switch Housing” and is released for remix if you wish.
Zero Switch housing.stl (70.6 KB)
Note: When mounting, please consider ease of removing the housing and switch for surfacing your spoilboard in the future, don’t trap it where it is not easy to remove temporarily.
Oh! Nearly forgot. the Molex connectors are thru Amazon as well, link follows:
(and they require a lot of patience to crimp)
