Cabinet Design Software
I know this is going to sound silly but before anyone thinks otherwise I am new at this and I have been told to find already made designs to “plug and play” into the foreman elite I bought until I feel “brave enough” to challenge myself and learn how to make designs in vcarve.
That being said, is there a design program where I can add height, width, and depth which will design a cabinet for a kitchen or bathroom and I can add detail to doors and drawers?
I know it sounds silly but thanks in advance
Personally, I use Rhino and have been using it for about 20 years now.
https://www.rhino3d.com/
Hey Dan,
sounds to me as if you have been told that before you travel to the destination you would like to go to or that you have in mind, you should first go to other places where others have already been.
I think if you are new to designing virtual models in 3D (which you want to export as toolpath and mill on your CNC machine), you should know that when attempting to master a CNC machine, learning to use a CAD/CAM software is what takes the most time. Therefore my opinion is, the sooner you start with working with a CAD/CAM software, the better.
If you want to use Vectric VCarve Pro, which many people here would recommend, …
The Vectric trial version however does not allow you to export g-code toolpaths :frowning:. But you can export them later when you bought VCarve Pro.
Free and open software
If you want to learn to create 3D objects and export them as toolpath to execute them on your CNC machine without paying money, you could also begin with
🢡 FreeCAD
which is completely free and open.
It offers vast documentation and tutorials:
FreeCAD has a lot of different capabilities, they are called Workbenches:
One of the workbenches used for CAD is the Part Workbench, another is PartDesign Workbench, you may also start with 2D objects on the Draft Workbench, which you can use to create 3D objects later.
The part of FreeCAD that exports toolpaths suitable for being executed by a CNC machine is the Path Workbench.
Wow!!! That’s what I am talking about!!!
Thank you so much!!!
Thank you I will look into it fer sure!!!
Thanks
I would also suggest looking for ways to use parameters or variables in your designs as you learn, this makes your designs more reusable by simply updating a value that then changes the cut size of various parts. This is particularly useful for things like doors and drawers where the variation of .010" in plywood thickness from one batch to another can result in poor joint fitment or even the drawers binding in the cabinet box.
If you’re up for it Fusion360 has a free version many people use. Some say it is tricky to use , i cant remember as i started tinkering with it years ago. it is good for parametric modelling (creating designs where you can change your design by updating a parameter you have created, like ‘plywood thickness’, ‘table leg length’… as mentioned above).
Great idea thanks I will definitely try and figure that out
Thanks, these are quite pricey but if it works then it might be worth the cost and time to learn
Thank you
All sounds overwhelming all these programs but I hear Fusion 360 a lot and the more I hear the more I want to learn. I got VCarve for free when I bought the machine and from what I have watched and read it seems to be a powerful program just apprehensive about this “Old Dog” learning “new tricks”…….
I toured a production shop with a 5x10 CNC combined with automatic feeders, labeling hardware, vacuum table etc (around a 200k setup) using Mozaik for design. They were cutting out about 10 cabinet boxes an hour. Definitely worth the price with that type of production hardware to back it up.
I don’t make many cabinets (maybe 10 a month) and I also use Fusion360 for most of my work and parametric modeling for my designs, yes it takes time but design once, reuse many :wink: . I will say Fusion can be a bit quirky in how it handles dimensions and parameters, generally I find it best to reference all dimensions from the same point or edge otherwise as it resizes things it may switch the left/right orientation of the dimension
For example, you have a part that is 12" wide (via a parameter), on that part you have a 1/4"x1/4" dado 1/2" from each edge fixed in place via a dimension to each edge. You now change the width to 10", the dado on the right is now 1/2" out in space, still technically 1/2" from the edge.
A better way is to measure all dimensions from one edge, makes a little more of a PITA to setup parametrically when your dimensions are now something like “width - (2*plywood_thickness) + 1/2”, it’s times like that the off the shelf software looks very attractive for the price.
It is Important to keep the mind sharp.
Dan, because you are using V-Carve already, if you go to the Vectric Forum site, and search for “EasyCabinetBaseVer15.1”. You can see that there have been guys there perfecting a gadget to aid in the making of cabinets. I personally have not used it, but they have put a lot of work in it. Not sure what version of V-Carve you are using or if there is a limit with the Gadget, but it may be worth checking into…
Thanks for the info and welcome to the forum
You might want to look at Sketchup - free to inexpensive (although I’m a big fan of Freecad, it’s a bit more complicated).
Thank you and these sound interesting and looking forward to finding a program that I can use well
I enjoy tinkercad for 3d printing. It is simple but I enjoy and easy for me to understand
Thank you
So it’s me again……so when making cabinets what is some of you all’s favorite materials such as plywood, hardwood etc etc and also what is a good thickness and what grade of wood or plywood?
Dan If you are using the Vectric software you can download a free gadget plugin whick will create cabinet design. You could check it out.
Wow that’s a lot of info……what’s thermofoil? So from what I am reading usually a veneer is placed over the internal wood. Thanks I was asking cause it seems like everyone uses Baltic birch plywood which seems to be a lot better than typical box store stuff. Gonna have to find a Baltic birch distributor.
Thanks!!
That is so good to know. I am looking to redo some cabinets in the main bathroom and for the shop.
Thank you for the information!!
