I’ve managed to design this in fusion after a great deal of experimenting, anyway the one thing I can’t do is put 4 x 6mm fixing holes with a 12mm counterbore.
No matter what I try to figure out how to do it I can’t
If you’re trying to draw them on the curved surface and extrude them it won’t work, either draw them on the flat part and extrude out using the “start at” parameter or I’d suggest an offset plane at the bottom of the counter bore, draw your 2 circles on it, extrude the larger one way and the smaller the other way. You can also use an offset plane above the part, draw the circles and extrude different depths. Many ways to skin a cat here.
Ah ok. Draw both of your circles concentric of the correct diameters. Extrude the smaller one all the way through the part. For the larger one when you extrude it change the “Start” value to “Offset” and then enter a value like 10mm in the “offset” field (adjust 10mm to whatever value works best), then drag it out to cut through the remainder of the part.
Change “start” to “offset” and use angle slider to make it perpendicular to the sketch plane. I don’t have access to Fusion right now so I can’t give you a better screen shot.
