I just received my machine and I am starting to clear the waste board and I could not find a way to run the program faster. I would assume I could manually adjust the speeds as it is working … yes/no?
Sorry, no. It’s an often-requested feature, but not currently available on the 1F.
I work with a lot of hard wood… I’ve found that slower feed rates and slower router feeds give the best results… test, test, and test some more… over time, you will know what works for the kind of work you do, and the material you work with… there is no “one size fits all”.
As for adjusting rates from the controller… I haven’t been able to adjust it. I just mess with it in software.
