When I’m doing a continuous jog my elite foreman will just stop midway through the move. At that point only double tapping home will work to move the machine. Has anyone else experienced this problem?
The rails will only move half way unless you home the machine. Upon boot up of the elite, you should estop, then home, then start any other operation.
Thanks for this. I had the same issue, and it’s because the Onefinity Elite owner’s manual says to jog the machine all the way to the back and THEN home the machine. So the instructions are in the wrong order in the manual.
They’ll be updated by end of day tomorrow :). Thanks for the heads up!
