Elite Foreman Setup
Foreman arrived a couple of days ago. Very good of Onefinity to double box the rails. The outside box of a couple of them looked pretty rough but the inside box was intact. Finished the support table and started installing today. Quickly ran into a problem, the top of slide on the left hand side is completely flat on top. The right side slide has a hump in the center so when you put Z bar on top of the right rail slide it fits and the bolts labeled for the X axis (qty. 8) fit. When you go to the left side the holes in the the Z bar don’t line up with the threaded recesses where you could you use the same bolts you did on the right side. Must be missing something somewhere.
Duh. I got the Z and X bar swapped. So, all is good. Well until I try to make something.
