After I save my toolpath and go to load the file on my flash drive I see a crv file and ngc file…I put both on the flash drive. It looks like the post processor likes to see the ngc file…correct?
The CRV file is your main Vcarve file. The Postprocessor is a PP file and it helps make the final G code file which is an NGC file.
For archival I put NGC’s and CRV’s into folders for later along with any other resources that I may need later.
There is no need to put CRV on the flash drive just develop a good naming process because there are no folders once you transfer to the controller.
