Cutting area off
I have a IF Journeyman. It is an upgraded Woodworker. I purchased the 50MM rail kiot so that I would have a 32" x 48" cutting area. All has been going well until now. I use Carveco software. The problem is that I set up a cut in Carveco, run the simulation and all looks good. I upload it to my IF using a BB controller and the cut is way off from the simulation in Carveco. I set the cut to start in the left lower corner and the cut itself is in the middle of the board. On the IF simulation, it shows the cut in the upper right corner. I have made several models and now they all do the same thing. I don’t know if it a Carveco issue or a IF issue. Any help would be much appreciated.
You are confusing the white boarder in the simulation as the material, which it isn’t. its a bounding box that only goes around the xyz starting point and the vectors, which is why it looks the way it does. run the file and you’ll see.
Thank you. Much appreciated. It works just as you outlined. Thanks for getting back to me so quickly. Fabulous!
