Day 6 of 2024 release week - Onefinity Pro Redline Series Promo - Free Spindle
Onefinity CNC PRO Redline Series Promo - Free Spindle
Announcing the Pro Redline Promo
Your choice of a Pro Series Onefinity CNC machine with a free Redline Spindle Kit included.
STARTING AT $2537*USD
For a Limited time
PRO Redline Series Promo - Foreman (48" x48" Cut Area)
Buy Now
PRO Redline Series Promo - Journeyman (48" x32" Cut Area)
Buy Now
PRO Redline Series Promo - Woodworker (32"x32" Cut Area)
Buy Now
What you get
When you combine the Onefinity PRO, Redline Spindle, XYZ Touch Probe, Joypad, Suckit Dust Boot and powerful Carveco software you get the most reliable, advanced, capable CNC on the market for an unmatched price.
Promo Includes:
  • Onefinity pro CNC (model of choice)
  • Onefinity Redline Spindle and VFD*
  • Carveco Maker Advanced 3D Cad Software
  • XYZ Touch probe
  • Joypad
  • Suckit dust boot
  • 1/4" Bit
Onefinity PRO Series
The Onefinity PRO Series is the perfect CNC machine for weekend warriors, hobbyists and small businesses alike. With its powerful stepper motors, Z-20 Heavy Duty Z-slider and high precision linear motion shafts, this machine delivers unparalleled accuracy and precision. The included Drag Chains with Plug and Play wiring make setup a breeze, while the large 10.8” touch display lets you easily control every aspect of your project. The included Joy Pad makes positioning your CNC incredibly easy and accurate while being a lot of fun! Upgrade your workshop today and experience the power and precision of the Onefinity PRO Series
Onefinity PRO Series, What you get:
  • Smart CNC controller with built in software allowing for operation without a computer.
  • Large 10.8 inch high definition industrial capacitive touch LED screen.
  • Rigid, high precision, hardened steel, linear motion Shafts.
  • High speed, long travel, Z-20 Heavy Duty Z-Slider.
  • Powerful, high torque, stepper motors on X, Y, B, and Z axis on the Foreman Size.
  • Stall Homing with auto squaring.
  • Fast travel, precision ball screws on all axis.
  • Conveniently located Emergency Stop.
  • Plug and Play wiring supported by drag chains.
  • Wi-Fi enabled.
  • Suckit Dust Boot (Included)
  • Plug and play XYZ Probe (Included).
  • Wireless Joypad makes jogging and positioning your CNC a breeze (Included).
  • Patent Pending Micro Tramming.
  • Quick and easy setup - start carving in under an hour.
  • Plug and Play with the Revolution 4th axis (optional accessory)
  • User friendly design.
  • Each unit fully production tested with a test carve to ensure proper functionality and quality.
  • A large “how to” library with a very helpful and supportive community.
  • Powerful Carveco Maker Advanced 3D Cad Software (1 year subscription).
  • Bits and Bits 1/4” down cut bit (Included).
  • And more…
Onefinity REDLINE Spindle (Included)
Onefinity REDLINE Spindles are the most advanced Plug and Play Spindle Kits on the market today. Featuring a sleek and stylish patent pending design, compact all metal enclosure, a high quality custom made Spindle with four ceramic bearing standard and the only safety approved Plug and Play complete Spindle kit on the market today and much more….
No other Spindle Kit on the market has the quality, reliability and safety that the Onefinity REDLINE Spindle has!
What you get:
Ready to go safety approved, complete Spindle Kit
Compact custom designed all metal enclosure
Custom made, high quality Spindle with quadruple bearing supported shaft (65mm DIA)
Ceramic bearings standard on all Spindles
All wires and cables properly grounded and shielded
Detachable display with built-in manual over-ride switch
All power lines and electronics properly filtered and grounded
Sleek and stylish patent pending design
Quick and easy set-up. Plug and play
Three (3) great mounting options
Works with all Onefinity machines
And much more…
SUCKIT works independent of the Z axis. This allows the bristles to consistently surround the area being cut , better contains debris and dust and provides a better seal so the vacuum is much more effective. SUCKIT does not reduce the Z axis travel, stays flat on the work piece at all times and is quick and easy to remove for bit changing.
Bits and Bits (1/4" Down Cut Bit Included)
Receive a quality 1/4” Down Cut Bit free of charge courtesy of Bits and Bits with the purchase of a Onefinity Pro Series CNC. In addition, Onefinity customers can get 20% off bits at (bitsbits.com) by using code 1F20 during checkout!
Wireless Joypad (Included)
Take your Onefinity to the next level with the Onefinity Joypad. Not only does this Joypad allow you to wirelessly control your Onefinity’s X, Y, Z motion, you can control the speed with 4 different speed setting. After using this Joypad, you’ll wonder how you got along without it. This is an amazing accessory and is now included free of charge!
PLUG AND PLAY 3-Axis Touch Probe (included)
The Onefinity 3-Axis Touch Probe allows you to quickly and automatically Zero your CNC’s X, Y, and Z axis or Z axis only. Our probe is incredibly easy to setup, just plug it into the dedicated probe port on the back of the controller. No soldering, crimping or screwing required! The XYZ Probe allows you to quickly and precisely zero your CNC’s X, Y, and Z axis
A LARGE “HOW-TO” LIBRARY WITH A VERY HELPFUL AND
SUPPORTIVE COMMUNITY
With a community growing at more than twice the rate of our closest competitors, the Onefinity community prides itself on being supportive, helpful, with a wealth of resources including how-to videos and informative blogs. With very knowledgeable community members and administrators, you will have access to many helpful creators and makers at all hours of the day and night. Onefinity has over 100,000 members across our forum, Facebook group, Instagram and YouTube channels. Watch a number of exciting educational series such as Morgan Hop’s “Onefinity Projects,” and Two Moose Design’s “5 Projects to Make and Sell” along with many others. You will find an abundance of resources and help to ensure you are successful and productive with your Onefinity.
Get yours today before this limited time deal ends!
Buy Now
Buy Now
Buy Now
Special Offer for units already shipped in November
Any units shipped in November will retroactively receive a free spindle. (The orders department will be reaching out to these customers in the in the coming weeks.)
*Offer includes 65mm 1.5kw spindle at no extra charge. Customers have the option to upgrade to a 80mm 1.5 or 2.2kw spindle at a upcharge of $75.
We really think so too!
If I was starting from the beginning, this is the way I would go. :smiley:
It’s great start at a fantastic price!
Can we get this deal with the Elite Foreman? :slight_smile:
This deal is for the PRO PROmo only.
This looks like a great deal! Do you know if the customer is permitted to delete the 10.8 inch touch screen and receive credit for it? My plan is to replace the 10.8 with a large monitor (22") and wireless mouse.
No, it’s sold with controller and 10 screen and spindle.
Thanks for the quick reply. It’s still a fantastic deal, regardless!
