Day 7 of 2024 release week! The Onefinity CNC Ultimate Elite Package with Spindle & ATC
:rocket: Elite CNC Deal of the Year: Unbeatable Price on a Elite CNC with Spindle & ATC! :rocket:
Starting at $3837*USD
For a Limited time
Ultimate Elite Package includes:
  • Onefinity Elite CNC (model of choice)
  • Easy-Z Tool setter
  • Onefinity Redline Spindle (80mm)
  • Easy ATC
  • (QCW table not included)
Continuing to Reinvent the CNC Experience!
Onefinity changed the CNC experience, first by inventing the quick and easy set-up and pioneering linear rails and ball screws at a price makers and small businesses could afford. This forced many manufacturers to copy us and abandon their plastic wheels and rubber belts. We then revolutionized accessories for small shops with products like the Rolling - Folding Stand, Wall Mount and Use Anywhere QCW. Now, Onefinity is trailblazing affordable production CNC’s with our industry first EASY ATC Tool Changer, Advanced Rotary 4th Axis (not included), “Anti-Skip” Closed Loop Stepper Motors and the most reliable Spindle we’ve ever tested; our Onefinity REDLINE Spindle. Purchasing a CNC for your business has never been more affordable and reliable!
Ultimate ELITE Package - Foreman (48" x48" Cut Area)
Buy Now
Ultimate ELITE Package - Journeyman (48"x32" Cut Area)
Buy Now
Ultimate ELITE Package - Woodworker (32"x32" Cut Area)
Buy Now
Watch the YouTube Video.
About the Elite Series Onefinity CNCs
The Onefinity Elite Series is one of the most advanced CNC lines on the market today. Featuring powerful “anti-skip,” closed loop stepper motors, “Z-20” heavy duty Z-slider, rigid, high precision, hardened steel linear motion shafts, a massive 15” touch display and one of the most advanced CNC controllers available. All this while maintaining our industry leading, user-friendly design with quick and simple set-up. No other CNC on the market can do what the Onefinity Elite Series can do!
Onefinity Elite Series Features:
  • Advanced, custom designed, Onefinity Masso Touch
  • Massive 15-inch high definition industrial capacitive touch LED screen
  • Rigid, high precision, hardened steel, linear motion Shafts
  • High speed, long travel, Z-20 heavy duty Z-Slider
  • Powerful “anti-skip,” closed loop stepper motors
  • Infrared homing sensors with auto squaring
  • Fast travel, precision ball screws on all axis
  • Conveniently located Emergency Stop
  • Plug and Play wiring supported by drag chains
  • WiFi enabled
  • Auto on/off router
  • Auto on/off Vacuum
  • Plug and play Tool Setter
  • Power Loss Recovery
  • Jump to Line
  • Continuous and incremental jogging via touch screen
  • Feed Rate Override - Adjust feed rate during a carve
  • Multiple Work offsets (G54-G59)
  • Micro Tramming
  • Quick and easy setup - start carving in under an hour
  • User friendly design
  • 7, 12 & 24 watt Laser (optional—plug and play)
  • Each unit fully production tested with a test carve to ensure proper functionality and quality
  • A large “how to” library with a very helpful and supportive community
  • Powerful Carveco Maker Advanced 3D Cad Software (1 year subscription)
  • ¼” Endmill
  • And much more…
Increased Speed, Now at 600 Inches Per Minute
When we first launched the Elite Series machines, we preset the rapids at 400 inches per minute to be conservative. The Onefinity Elite Series has always been capable of performing higher rapids and higher cutting speeds. The limiting factor has always been the router. With the addition of the Onefinity Spindle Kit by Redline Spindle you can unlock more of the Onefinity Elites potential. We have also improved the stepper resolution to produce incredibly smooth operation.
All Ultimate Package machines will ship with rapids of 600 inches per minute . No other CNC on the market can do what the Onefinity Elite Series can do!
(All Elite Series will now ship with the increased rapid settings of 600 IPM)
Onefinity REDLINE Spindle (Included)
Onefinity REDLINE Spindles are the most advanced Plug and Play Spindle Kits on the market today. Featuring a sleek and stylish patent pending design, compact all metal enclosure, a high quality custom made Spindle with four ceramic bearing standard and the only safety approved Plug and Play complete Spindle kit on the market today and much more….
No other Spindle Kit on the market has the quality, reliability and safety that the Onefinity REDLINE Spindle has!
Onefinity Spindle Kit by Redline CNC Features:
  • Ready to go safety approved, complete Spindle Kit
  • Compact custom designed all metal enclosure
  • Custom made, high quality Spindle with quadruple bearing supported shaft (available in 3 sizes)
  • Ceramic bearings standard on all Spindles
  • All wires and cables properly grounded and shielded
  • Detachable display with built-in manual over-ride switch
  • All power lines and electronics properly filtered and grounded
  • Sleek and stylish patent pending design
  • Quick and easy set-up. Plug and play
  • Three (3) great mounting options
  • Works with all Onefinity machines
  • And much more…
Onefinity Easy ATC (included)
Please note: The EASY ATC is an advanced accessory and may require some programming. We recommended this only for those familiar with using a CNC
The Onefinity Easy ATC is the most affordable and easiest way to add a reliable automatic tool changer to your Onefinity CNC. The Easy ATC features a sleek and stylish patent pending design, easy to load tool pockets, load and unload sensors and is designed to use with the Onefinity SM Dust Shoe to ensure your shop stays clean.
The Onefinity Easy ATC is the only Automatic Tool Changer on the market that allows you to use your existing collet Spindle to easily change tools automatically. In addition, the Easy ATC features Load and Unload sensors to help ensure your tool gets loaded properly. If a tool gets loaded incorrectly, the sensors will trigger an alarm and stop the CNC until the issue is corrected.
Onefinity Easy ATC Features:
  • Easy ATC with 4 Tool Holders
  • Patent Pending design
  • Four (4) high quality Spindle Collets
  • Load/Unload Sensors on each Tool Holder
  • Access to RapidChange ATC Tool loading software
  • Fully Supported by RapidChange ATC and Onefinity
  • All required wires and cables
  • Mount Anywhere Table Mounting Bracket (Optional)
  • Easy ATC QCW Mount for quick, easy, reliable installation (Optional)
  • And much more…
Get the Ultimate Elite Package today before time runs out. This is the lowest price it will ever be offered at!
Buy Now
Buy Now
Buy Now
Here is a breakdown of the key terms and conditions you agree to by placing an order for the Ultimate Elite Package, with a specific focus on the Onefinity Easy ATC tool changer: 1. Pre-order. You acknowledge the Onefinity Easy ATC is being pre-ordered and will be delivered to you separately from the Onefinity Elite CNC Machine, the Easy-Z Tool Setter, and the Onefinity Redline 80mm Spindle. 2. Delivery of the Onefinity Easy ATC: We anticipate we will begin receiving shipment of the Onefinity Easy ATC by February, 2025, and we expect to receive shipment of the Onefinity Easy ATC no later than April 30th, 2025. 3. Refund Policy: If, for any reason, we are unable to ship the Onefinity Easy ATC to you by April 30th, 2025, you will receive a full refund for the cost you paid in the pre-order of the Onefinity Easy ATC tool changer. 4. Price and Availability: The price and availability of the pre-ordered Onefinity Easy ATCs are subject to change. However, the price you paid at the time of preorder will be maintained. 5. Additional Terms: The purchase of the Ultimate Elite Package is subject to our general terms and conditions, which can be found on our website. In essence, this agreement outlines the expectations and protections for customers who order the Ultimate Elite Package, which includes a pre-order for the Onefinity Easy ATC. It ensures transparency about potential delays, guarantees a refund for the cost of the Onefinity Easy ATC tool changer if the delivery timeline is not met, and clarifies that the original pre-order price for the Onefinity Easy ATC will be maintained.
General Disclaimer: While Onefinity has made every effort at the time of publication to ensure the accuracy of the information provided herein, product specifications, configurations, system/component/options availability are all subject to change without notice. Product design specifications and colours are subject to change without notice and may vary from those shown. Errors and omissions excepted. Images displayed are for illustration purposes only. The images are intended to help illustrate the product and it’s functions and are not indicative of actual relative differences.
Is this meant to say Day 7 in the title or is the “main” day 7 announcement still to come?
From the promotional images, it looks like there are 3 rails on the CNC (by default). I am assuming I don’t need to buy another X-50 Stiffy for extra rigidity. Could you please confirm?
Hm. It actually makes sense to sell or donate my old journeyman and buy a new foreman.
Agreed but then there is the variable of selling the old machine for who knows how much and who knows when. Do people typically have success selling their machines here or somewhere else?
I was thinking the same thing. I paid the same price for my Pro series with all my add-ons as this foreman package. Might be worth it if I can get a good price for it.
So many options now I need to list everything out in excel price wise and see what makes the most sense
Asked on the livestream, but just as they were wrapping up. Is there a way to buy the elite package but still “sell” our old machine back to you guys? The savings on the bundle are too good to pass up, but I’d still love to support the IPP program and get my machine to a vet/first responder.
I’m in the same boat and it doesn’t seem like it. Stone said buy new and sell old machine. Hopefully someone in my area wants one and doesn’t sit too long because I want to get the elite foreman
There is not @nikkishins
Are the 48” rails all identical and can they be used for both x or y? I have an original x50 journeyman with journeyman qcw and rolling stand and want to take advantage of the ultimate promo. I don’t think I need the foreman size, but in the future if I want to upgrade the rails, can I just buy the two foreman rails? The only option on the site looks like foreman ipp upgrade for $1,700 when some of the other rails for purchase are around $200. It would save me a lot by not having to buy the foreman stand now etc. Long story short, is IPP the only way to upgrade to foreman rails or can I buy the two rails individually?
I’m supper excited about this package. I do have one question. Does the dust boot come with the package? If not, which one do we order for the ATC?
I’m sitting here in the UK with my fingers hovering over the buy button. What time will I be able to buy it? It’s 14:04pm here…
I had also email support about this. Here is the response if anyone else was wondering.
One challenge that most ATCs face is dealing with dust collection. We know that dust collection is a big deal, that’s why our engineering team has been working closely with the RapidChange ATC team to help develop a variation of their existing product that will work with a dust shoe. Out of this came the EASY ATC. The EASY ATC Works with our new spindle mount dust shoe, the Suckit SM (Spindle Mount). The Suckit SM is coming soon and will be available to purchase separately before your Easy ATC ships.
From what they said last night, the dust boot will be a little longer because they are still doing tests on it and you would have to order it later.
Looking into the ATC, if you want more than 4 tools you would need to order 2 or more ATC systems, pretty pricey just to add tools, am I correct in this thinking?
Pat
You are correct on both - need for more magazines and significant cost.
I setup my ATC system years ago and built it around my modified Onefinity, Masso G3 controller, and Jianken ATC spindle. I did it myself because I wanted to learn, had the time, and had the funds. Such systems, with all the electrical and pneumatic components as well as tooling are an investment in the many thousands of dollars.
The RapidChange will offer the same overall functionality, and for a lot less of all the aforementioned expenditure and work. I think for those who really want it, or perhaps business owners who will find the time savings a cost savings, it will likely be a very good value. Ultimately it is up to each individual to decide its value.
I noticed the same but then saw the note
Listing picture shown with optional 3rd x rail stiffy installed. This does not come standard with the machine.
So I ordered the Stiffy
In the UK also and hit the buy button so can’t wait now to get my Ultimate Elite Journeyman. Really looking forward to getting this set up and running so i can get rid of my existing Ooznest workbee. Going from a 520mm x 770mm work area to a 812mm x 1210mm so looking forward to the extra room.
Been told there is a new dust collection boot but no date on when it will be available. I hope that I wont have to pay an additional shipping on that and it is available for when my machine is ready for despatch.
