Dip Switch setting confusion
Setting up Elite Masso. Confused on the service bulletin and dip switch settings. Some videos directly contradict the text.
  1. Is it 1, 4, and 5 off; or just 1 & 4 off? My machine shipped around April 2025 with motors set to 1, 4 off.
  2. Is Z dip settings same as all others?
  3. Do I need the service bulleting settings file? My settings seem to already reflect what the bulleting says.
1,4,5 off/down
2,3,6 on/up
These are correct.
This is more confusing is 5 up or down and where is 3
Ok, thank you. Should probably update the service bulletins and make sure video matches. Also the β€œElite Series Assembly with Masso (Revised)” video, which I assume is the latest and greatest, is also wrong. It shows 1,4 off.
I think he meant 2,3,6 are on. Typo. I did this and seems to work and sound good. But I have nothing to compare it to as first one. What happens if 5 if off? Do they blow up?
woops. corrected.
1,4,5 off/down
2,3,6 on/up
Try again same thing.
Glad I don’t have a Masso
Funny, you might be tired. You wrote 2,5,6 again, instead of 2,3,6.
Third try is the charm. :slight_smile:
