Dry Run throws Z axis soft alarm
After updating my PP to the Masso version, I’m no longer able to use the Dry Run feature. Machine is an Elite Journeyman.
Attached are my current settings and a sample .nc file from Fusion (and just added F2 screenshot).
If I:
  • Boot machine and home
  • Probe/Set XYZ
  • home again for good measure
  • Load Outline.nc
  • Activate ‘Dry Run’, Cycle Start
I get a ‘Soft alarm on Z axis motion line 38’ which is N150 in the file:
N150 G19 G3 Y30.95 Z-0.125 J0. K0.025
-0.125 is within my Z limits. I know this .nc file is referencing the G54 offset…but why is Dry Run doing anything other than moving Z to the upper limit?
Since the file will run and cut normally it seems like a configuration problem with the Masso controller; but a problem where?
MASSO Settings v5.07 (G3-18275).txt (13.9 KB)
Outline.nc (1.7 KB)
Print Screen-002.bmp (3.0 MB)
Just wanted to note that I’m having this problem as well on a command.
N80 G18 G2 X-202.863 Z-9. I0.318 K0.
Z-9 is well within soft limits and this toolpath runs fine and does not cause an alarm except in Dry Run mode. Just based on the commonality between our failed commands, I suspect that this might be caused by Dry Run not properly dealing with G17/G18/G19 axis shifts.
