Dust Collection
My Journeyman has not arrived yet, but I have purchased the Harbor Freight 70 gal dust collection system and upgraded the bag with a 1 micron bag and a cyclone separator. The system has a 4-inch hose, and I ordered the Journeyman with the Suckit dust boot that will not accept a 4-inch hose. Do I reduce the hose at the router or prior to the CNC machine?
I own the same Harbor Freight dust collector. Any reduction of the hose size from 4" will result in a notable loss of suction. You want the reduced area to be as small as possible, ideally at the router as opposed to running any length of 2.5" hose.
Additionally — Down the road, you may want to consider a filter cartridge for that dust collector if you plan on branching it off to multiple tools. This is the one I use from Wynn Environmental 35C222NANO Cartridge Kit. It has much greater surface area than a filter bag (222 sq ft), allowing the dust collector to operate unrestricted, and you can easily clean it with compressed air from the outside (the dust drops into the bag).
I have 3 shop vacs, a $600 Bosch vac
and a 1 1/2 hp Shop Fox with a 2.5 micron bag and Oneida cyclone. Shop vacs all have Home Depot Dustopper
Takeaways ;
Dustoppers are great and really help keep the filter clean
Shop vac s are ok for table saws, routers, band saws and small bench sanders.
Bosch system Hepa filter is good and the system works good when connected to small tools. Better than nothing on a planer but so many chips came out the back I had to build a box to catch them
Shop Fox works great but the 2.5 micron bag does not stop mdf dust dust
I think it would be best to reduce right at the cnc machine. I had same problem when I started out but have gone to a 4ā€ collector on my cnc machine. I made my own boot out of wood and lexan! Drew it out on Vcarve with a lexan top. That is what cnc machine are made to do! Couldn’t see buying one!
So does say a Fein do a good enough job at removing most debris? My 2hp dust collector is LOUD and I’d like to tone things down a bit. It’s fine when running my table saw or planer for a half hour or so, but for a 3 hour carve it’s kind of annoying. Right now I have my 4" hose reduced to 2.5" so I’m thinking maybe a Fein would give me similar suction.
My Fein works great and is relatively quiet compared to any other collection system.
Linking to what I just posted in another thread about my latest dust collection endeavor:
hi looking to print out the elbows you are using for the hose . do you know where i can get such a file.
I got the files from Thingiverse.
https://www.thingiverse.com/thing:3235016
Martin
I was able to find a basically brand new Oneida Dust Deputy 4/5 with included bin for 150 on Facebook Marketplace and from another person a 1.0HP wall hanging Grizzly which look hardly used for another $150. Cyclone will probably kill CFM by 30 percent but a similar combo worked well for me in the past and kept me from having to empty the bag. I don’t know why 1F insists on using 2.5ā€ for its dust boot. I will use it to start then make my own with 4ā€ inlet.
mine is very simple I have been using it for years now. craftsman 6 hp shop
vac 2.5 inch dust hose dust deputy separator. all mounted on a wheeled wire rack so it is movable and easy to empty when needed. the bucket is 20 gallons available om amazon total cost for the whole thing is about 250 to 300 bucks
Rowdy Roman Boom arm? And how have you grounded things? Thanks
I have not as yet i am waiting on the wire and a new ground spike.
I went with the Dewalt Stealthsonic. That thing is very quiet compared to the others.
We have one of these in the shop and it is much quieter than our others.
