Elite/ATC/dust boot
For those of you with Elites and RC ATC what are you using besides sidekick for your dust boot that is compatible with the ATC?
Any ATC pro/con comments welcome.
I’m forever contemplating a Masso upgrade with ATC and looking at all options.
Thanks-
I have the RC ATC from Rapidchange, I went with the easy boot from Francis Creations.
The combination works very well, I am especially pleased with the ATC from RC, it works very well.
Pat
Thanks Pat,
I appreciate the response. I looked at a youtube vid of that product. Do you find the trimmer for raising and lowering the boot could use a few less turns or is it about right? The video only showed a brief adjustment. It’s a minor detail, just wondered. Lastly, do you use a 4" or 2.5" and if 2.5 does it pull pretty well?
Thanks!
The knob is not connected to the lead screw, it is an encoder and when you turn the knob it is quite fast to raise and lower the boot, seems like a 3/4 of a turn does it. I have the 2-1/2 vacuum connection and so far it works pretty good, I have used the Suck It from 1F and the Nighthawk and this one is comparable, my vacuum is just a shop vac with a long hose.
Hope this helps
Pat
Great! Thanks again Pat.
