Brilliant Explanation, that makes so much sense now!
I just switched to PPR of 2000 and cut some air, I did not encounter any problems.
First I opened the motor cover an set switch 1 and 4 to the off position, with the controller powered off. The I change the X,Y and Z axis motor settings in tab F1 and saved.
I also changed some other settings, and the wild noisy janky beast became much tamer.
I know this might not be for everyone, but as I said, I am not looking for speed but precision.
The top line of the picture it actually shows the Axis resolution, perfectly in line with my PPR/step size chart from post 15.
I reduced my Acceleration further from originally 500000 mm/s2 to 25000 mm/s2. It has still plenty of jerk, maybe still too much for me. The 6m/min speed limit is temporary, I think I want it back to 10m/min for roughing and limit the speed for the finishing tool path in Vcarve.
*What I just notice is that it looks like at a max pulse rate of 12.5 kHz the motor would max out at 100mm/sec, which is 6m/min if I did not make a mistake.
I have to think about that, a PPR of 1000 would have a max speed of 12m/min, which means it would not limit the max speed of the 1F of 10m/min… I hope my math is correct, it is past midnight.
I am making a bold claim now:
The Onefinity Elite setting for the PPR (pulse per revolution) should ideally be set to 1000, not 400. This would give the Elite the highest possible precision without compromising the max speed.
Prove me wrong.
