If your Elite machine is not homing, try the following:
- If your machine is on, ensure you power off the machine first.
- Ensure each axis (x,y,b,z) are 3 inches or so away from the homing sensor.
- Power up the machine.
- Push in the estop.
- Release the estop.
- DO NOT HOME.
- Go to the F1 Screen. (See this for password: What is the password for the Masso Controller? 1)
- In the center column, scroll all the way down so all 4 homing sensors and motor alarms are shown.
- Ensure all are green/low.
- For any that are red/high (except tool setter and estop), tap that line once and push the space bar. this will switch it from red/high to green/low.
- Once all green/low, reboot.
- Power up and estop in and out.
- DO NOT HOME
- Go to the F1 screen.
- Ensure the settings took and it’s all green/low.
- If it is, double tap home and all should work.
This is what the machine should look like:
See this post to test the sensors:
