IMPORTANT! – Please read these release notes before updating.
IIMPORTANT! – Before updating make a backup of your current settings.
https://docs.masso.com.au/wiring-and-setup/save-and-load-settings
IMPORTANT! – Before updating save a copy of your printable file, print it out and use it to check your settings after the update is complete to make sure all settings are correct.
NEW in v5.07
Support for MASSO myWorkshop phone app – Now the users can monitor machine and job status remotely on their phones or in myWorkshop platform on PC, myWorkshop PRO
New MSG commands – Send custom messages to myWorkshop phone app or PC using the new MSG commands, MSG - Message command for screen and remote alerts
IMPROVEMENTS & BUG FIXES
Spindle Auto On/Off – Logic improvement for spindle override speed after feed hold.
MASSO Link – Improved file transfer error checking and faster file transfer speed.
WiFi locking – Fixed an issue where the WiFi communication would stop and the controller had to be power cycled.
How to update your Masso firmware:
https://docs.masso.com.au/getting-started-guides/installing-masso/loading-software-to-masso-g3
Onefinity Users will see two options under 5.07 firmware, The top one is 'Mill, Router, Plasma, Oxy, Waterjet" and the bottom one is ‘lathe’.
You only need the one labeled ‘Mill, Router, Plasma, Oxy, Waterjet’.
DO NOT DOWNLOAD OR INSTALL THE ONE LABELED ‘LATHE’. This is not used with a Onefinity machine
Default Configuration settings for Onefinity Machines:
Questions or issues with the Masso firmware update? You can reach out to Masso on their help desk here: Support | CNC Support for All Users | MASSO
Don’t have access to your my masso workshop account? Email INFO@ONEFINITYCNC.COM if you never received your log in info and include your serial number of your masso controller and order number of your Onefinity machine.
