EMS-9110 doesnt work?
I ordered a EMS-9110 and not a EMS-9113 https://www.amazon.com/dp/B07WBYFX24?psc=1&ref=ppx_yo2_dt_b_product_details
I plugged it and paired it as the 1F tutorial video showed. and it does nothing at all none of the buttons do anything.
Did I screw up, and this one plain won’t work, or is there something I can try?
I plugged it into my laptop and Windows recognized it just fine so the joypad is functional.
You can see the differences in the two models here.
https://www.easysmx.com/
The major difference is one is hard-wired and USB powered and the other is wireless and powered by a pair of AA batteries. Looking at both manuals they function the same and changing modes is the same.
Per the manual the gamepad should initialize in Xinput more (LEDs 1 & 2 on).
This is supposedly the mode we need for the Onefinity controller (RPi) connection.
To change modes press and hold the Home button for 5 seconds to jump to the next mode. Each subsequent press and hold of the home button will cycle to the next mode in this order:
LEDs 1&2 Xinput (default mode)
LEDs 1&3 Dinput emulation mode
LEDs 1&4 Dinput digit mode
LEDs 3&4 Android mode
Controls layout
The manual gives no explanation as to the differences between the modes.
For me, my ESM-9013 gamepad initializes in Android mode with LEDs 3&4 lit. I cycle through the modes to get to Xinput mode and everything works as it should as far as controlling X,Y, and Z on the CNC. When the gamepad goes to sleep (which the manual does not talk about at all) and I then want to use it so press any button to wake it up it reverts back to Android mode (LEDs 3&4) and I have to change modes again back to Xinput mode. But if you hold the button down a little too long it jumps right past the next mode and goes to 1&3 or 1&4, which means you have to try again to get to the default mode.
Here are the relevant pages from the ESM-9013 manual enlarged to a readable size.
Return it and try https://www.amazon.com/gp/product/B086PSGYL7/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Cheaper and it worked for me w/o any issues.
Enjoy,
@Bob_D
The one I got, the EMS-9110 is a wireless model as well.
I found the manual on their website, it shows LEDs 1 and 4 should be on for Xinput mode. Which is default But nothing works in that mode on mine if I change it to 2 of the other modes, then x and y work, but the speed buttons are all mis-mapped, and Z does nothing.
I think I will just return it and order the correct one. :confused: Thank you for your help, it got me closer.
Your welcome. Glad I was of some help.
Sorry for the problems you’re having.
Still trying to figure mine out too.
