Engraving With Fusion 360
Attached is a rendering of an engraving of some artwork I am trying to do. I am looking at doing this with a 1/16" bit. When done, I would like to soften the edges by running a v-bit around the edge. Not much, just a touch to soften the edge a bit.
I think I can do the engraving part, however I’m not sure how I would do the v-bit portion. Is this possible in Fusion 360?
Any other advise on the best way to do this?
Thanks
Martin
Give this a go, Fusion 360 - Chamfer Toolpath Options - YouTube.
If your CAD model has contours then you can chamfer the edges with a vbit.
What @AndyP posted. Run a chamfer tool path :+1: easy peezy
