Error: motor 0 fault
I don’t kno what went wrong. Once it finished up the tool path with my 90v bit but before I needed to change to my 60v bit and re zero and run the next tool path, it tells me “Error: motor 0 drive fault”. I’ve shut it down, unplugged every wire and plugged them back in, then restated, and the same error is still there.
I know I bought it over a year ago, but with work and other stuff I haven’t ever really had much time to get to it. I had to have a guy new me that has one walk me thru some things to get started. This is only maybe the 7th time using it. And he doesn’t know what to do either. Please help
@Photozooka
Your machine may be out of warranty but i believe support@onefinitycnc.com will help you try to diagnose your problem. They are very responsive so give it a try.
