Error 'utf-8' code cant decode
You’re file was not gcode. Also take care when you edit on windows because you’re file had an extra .txt at the end.
Give me some news about if you’re machine is now up (i.e. not freeze)
Apologize for delay, couldn’t respond yesterday reached my max number of replies on forum. Anyway I tried to delete file but no luck, not sure what I am doing wrong
20210417_210340|666x500
Run sudo -i then retry the delete.
´sudo -i’ is a command to enable you to run as root. Root is the owner of the file regarding your image.
I don’t know a lot about these Lenox commands, not sure what sudo is
how would i type that in?
Sorry edited my previous post
Not 100% sure on how to type all this in
Type:
sudo -i [enter]
Then redo the same delete command that failed
Thank you! that fixed the problem
Next release will fix (prevent from loading) wrong file type,
Thanks again. Now i need to figure out what the hell is a post processor is in Carveco
Search this forum with carveco
will do. thanks again
I’m having the same issue on mine. When I try the ls -lart/var/lib/bbctrl/upload I receive a response of ls:
invalid option - - “/”
got it to work. Thank you. I may have keyed something in error originally.
Ok there was a space missing between -lart and /
@blaghislain - I’m just curious - why can’t you do this over the network? It’s just a bunch of shell commands that should work equally well via ssh.
In fact we can. I edited the procedure. Original statements came from a onefinity post.
Thanks for your comment.
How do you reboot this thing after putting in the commands?
I’ve tried -r, -R, the help command tells you how to do it but it doesn’t work.
My machine is stuck on processing a file I tried to delete and literally does nothing now
I ajusted the procedure
