I have tried that. It doesn’t reboot.
try typing the command: sudo reboot
If this doesn’t work use the off-on controler box switch
Seem to miss a space after rm and another ´ at the end. Off/ on and redo
Also the case of all letter should be the same
Thank you ill give that a try.
sorry for the confusion. The command is:
rm[space][squote]/var/lib/bbctrl/upload/your filename.nc[squote]
all the space are important and all the letter are case sensitive
I definitely missed that first [space] and last [quote]
That fixed it. Thank you very much!
I am so sorry but where is the command line I cannot access anything other than this loop. I try clear and it
goes to this. I hit clear again and nothing happens I hit ok it goes to home machine I cancel
And I get this
it has been processing all day for a very simple sign.
HELP. I just do not get it. I also has highlighted in orange Update to v1.0.8 but not her on the touch screen works, I also have it hooked up to my computer an that is what the photos are from. Oh and the emergency stop button is flashing orange
Thank you I did get it. But struggling and learning the hard way.
You’ll need to perform this: How To Remove All Gcode Files Manually
You’ve most likely uploaded the Design file and not gcode.
After you perform this, update to 1.0.8 and it will prevent this mistake from happening in the future.
