Tried to use 1F for first time to surface spoil board, now machine is froze trying to process new file (for several hours now). Is there a reset button on controller? Cant delete file nor do I have access to any functions. I shut down and restart and home machine and error pops back up. Need help.
Can you upload the file and explain how you created it?
created file in Carveco it kept giving me errors and wouldnât run machine, stating invalid word âINâ. So I opened code in word pad and removed âINâ, then reuploaded and now froze.
After editing I donât think the file ended up as a PLT File
This is what I usedâŚ
PU;PA;SP1;PU;PA406,-0;PD;PA406,406;PA-406,406;PA-406,-406;PA406,-406;PA406,-0;PA813,-0;PA813,813;PA-813,813;PA-813,-813;PA813,-813;PA813,-0;PA1219,-0;PA1219,1219;PA-1219,1219;PA-1219,-1219;PA1219,-1219;PA1219,-0;PA1626,-0;PA1626,1626;PA-1626,1626;PA-1626,-1626;PA1626,-1626;PA1626,-0;PA2032,-0;PA2032,2032;PA-2032,2032;PA-2032,-2032;PA2032,-2032;PA2032,-0;PA2438,-0;PA2438,2438;PA-2438,2438;PA-2438,-2438;PA2438,-2438;PA2438,-0;PA2845,-0;PA2845,2845;PA-2845,2845;PA-2845,-2845;PA2845,-2845;PA2845,-0;PA3251,-0;PA3251,3251;PA-3251,3251;PA-3251,-3251;PA3251,-3251;PA3251,-0;PA3658,-0;PA3658,3658;PA-3658,3658;PA-3658,-3658;PA3658,-3658;PA3658,-0;PA4064,-0;PA4064,4064;PA-4064,4064;PA-4064,-4064;PA4064,-4064;PA4064,-0;PA4470,-0;PA4470,4470;PA-4470,4470;PA-4470,-4470;PA4470,-4470;PA4470,-0;PA4877,-0;PA4877,4877;PA-4877,4877;PA-4877,-4877;PA4877,-4877;PA4877,-0;PA5283,-0;PA5283,5283;PA-5283,5283;PA-5283,-5283;PA5283,-5283;PA5283,-0;PA5690,-0;PA5690,5690;PA-5690,5690;PA-5690,-5690;PA5690,-5690;PA5690,-0;PA6096,-0;PA6096,6096;PA-6096,6096;PA-6096,-6096;PA6096,-6096;PA6096,-0;PA6502,-0;PA6502,6502;PA-6502,6502;PA-6502,-6502;PA6502,-6502;PA6502,-0;PA6909,-0;PA6909,6909;PA-6909,6909;PA-6909,-6909;PA6909,-6909;PA6909,-0;PA7315,0;PA7315,7315;PA-7315,7315;PA-7315,-7315;PA7315,-7315;PA7315,0;PA7722,0;PA7722,7722;PA-7722,7722;PA-7722,-7722;PA7722,-7722;PA7722,0;PA8128,0;PA8128,8128;PA-8128,8128;PA-8128,-8128;PA8128,-8128;PA8128,0;PA8534,0;PA8534,8534;PA-8534,8534;PA-8534,-8534;PA8534,-8534;PA8534,0;PA8941,0;PA8941,8941;PA-8941,8941;PA-8941,-8941;PA8941,-8941;PA8941,0;PA9347,0;PA9347,9347;PA-9347,9347;PA-9347,-9347;PA9347,-9347;PA9347,0;PA9754,0;PA9754,9754;PA-9754,9754;PA-9754,-9754;PA9754,-9754;PA9754,0;PA10160,0;PA10160,10160;PA-10160,10160;PA-10160,-10160;PA10160,-10160;PA10160,0;PA10566,0;PA10566,10566;PA-10566,10566;PA-10566,-10566;PA10566,-10566;PA10566,0;PA10973,0;PA10973,10973;PA-10973,10973;PA-10973,-10973;PA10973,-10973;PA10973,0;PA11379,0;PA11379,11379;PA-11379,11379;PA-11379,-11379;PA11379,-11379;PA11379,0;PA11786,0;PA11786,11786;PA-11786,11786;PA-11786,-11786;PA11786,-11786;PA11786,0;PA12192,0;PA12192,12192;PA-12192,12192;PA-12192,-12192;PA12192,-12192;PA12192,0;PA12598,0;PA12598,12598;PA-12598,12598;PA-12598,-12598;PA12598,-12598;PA12598,0;PA13005,0;PA13005,13005;PA-13005,13005;PA-13005,-13005;PA13005,-13005;PA13005,0;PA13411,0;PA13411,13411;PA-13411,13411;PA-13411,-13411;PA13411,-13411;PA13411,0;PA13818,0;PA13818,13818;PA-13818,13818;PA-13818,-13818;PA13818,-13818;PA13818,0;PA14224,0;PA14224,14224;PA-14224,14224;PA-14224,-14224;PA14224,-14224;PA14224,0;PA14630,-0;PA14630,14630;PA-14630,14630;PA-14630,-14630;PA14630,-14630;PA14630,-0;PA15037,-0;PA15037,15037;PA-15037,15037;PA-15037,-15037;PA15037,-15037;PA15037,-0;PA15443,-0;PA15443,15443;PA-15443,15443;PA-15443,-15443;PA15443,-15443;PA15443,-0;PA15850,-0;PA15850,15850;PA-15850,15850;PA-15850,-15850;PA15850,-15850;PA15850,-0;PA16256,-0;PA16256,16256;PA-16256,16256;PA-16256,-16256;PA16256,-16256;PA16256,-0;PU;PA0,0;PU;SP0;
Itâs not a gcode file. If youâre frozen you will need to delete the file using command line. Be careful all command are case sensitive and space are important.
note: Edited step 6 on 2021-04-23. Edited step 1 (ssh portion)
Procedure
- Connect the touchscreen and start up the controller as usual. This operation can be performed on the touch screen. It will also work if you try to perform it via ssh from network (then go directly to step 5).
- Plug in the USB keyboard to one of the free USB ports on the back of the controller.
- After the controller boots up, you should see the machine control interface.
- Using the keyboard, hold down the Control key and press the âtâ key followed by the âcâ key. (Control-t, Control-c) This should open up a new terminal window.
- To locate the file, type the command: ls -lart /var/lib/bbctrl/upload
you will see an output like this one
total 1304
drwxr-xr-x 5 root root 4096 Oct 17 2019 ..
-rw-râr-- 1 root root 1327086 Apr 17 19:29 your filename.nc
drwxrwxrwx 2 root root 4096 Apr 17 19:29 . - To delete the file:
a. Type the command: sudo -i
b. Type the command: rm â/var/lib/bbctrl/upload/your filename.ncâ
type rm[space][squote]/var/lib/bbctrl/upload/your filename.nc[squote] - Reboot your machine: Type the command: sudo reboot
Thank you! I will try this.
I havenât used carveco but there should be instructions somewhere on exporting toolpaths as gcode. Gcode is the only thing you upload to the controller.
typed in command and it reponded back with : ls -lart /var/lib/bbctrl/upload: No such file or directory
give me the output of:
ls /var/lib
bash: ls/var/lib: No such file or directory
there is a space between ls and /
okay, wasnt adding space. just responded with âblue txtâ
in fact just want to know if you see bbctrl in the output
yes sir, bbctrl is listed
please try again the original command. there is a space after ls and -lart
got a response back, and found file
continue to step 6. be careful the are other space. Maybe also in your filename
Step 6. To delete the file type: rm â/var/lib/bbctrl/upload/youre filename.ncâ
my file name is- Surfacing x.plt.txt
do i need to add â.ncâ after file name?
you have to use exactly your filename as found (i.e. the bold part of step 5). itâs case sensitive and space are also important
