Hi Dan,
This is awesome. I couldn’t find models I liked, so I started building my own in Fusion 360. I was almost done when this showed up in my "What You Have Missed " forum summary. I continued on my own, because it’s as much about learning how as anything else. Today, I see the change you made to the plug and socket. That’s really nice. I was putting a rim on the outside of the female half of my design, now I’m stealing yours.
I created a parameter named systemID for the system’s inside diameter, and I keep it the same for the magnetic coupler ends. It’s just a quick way to know that a coupler I print will match ones I already have by keeping the system size the same. It’s what you did for Dave. I just like the idea of having the feel more global, I know if it is set at the top, then everything I will print fits into the same family (4", 2.5" )
One thing I really want to work into mine is a place for an O-ring to provide a good seal—no high-pitched sounds of sucking air leaking at the couplers. I’m curious about your thoughts on it. A second thing would be allowing the hose connection to swivel. In one section of my shop, I use a Rockler dust right system. It has a swivel connection between the hose and the dust collector, which helps prevent the hose from twisting.
Thanks again for sharing the great application
