Thank you @blaghislain! Now, time for me to learn how to use Fusion 360.
@blaghislain thanks for all your great work on post processors. If I knew how to use/contribute to github, Iâd do this there:) One day I will learn.
- I think there is a small bug in the current PP for F360 for spindle delay. âInsert a delay (gcode S4 Px) if time <> 0â â I think it should be G4 Px rather than S4 Px.
- I added a âMySafePlaceâ option to the safePositionMethon
safePositionMethod: {
title: âSafe Retractsâ,
description: âSelect your desired retract option. âClearance Heightâ retracts to the operation clearance height.â,
type: âenumâ,
values: [
{title: âG28â, id: âG28â},
{title: âG53â, id: âG53â},
{title: âClearance Heightâ, id: âclearanceHeightâ},
{title: âMySafePlaceâ, id: âMySafePlaceâ }
value: âMySafePlaceâ,
scope: âpostâ
This allows me to be more OCD on movement before/after gcode execution. Iâve found it helpful when you want to move the spindle away from the stock for bit changes etc.
Question, when I download the onefinity-pos-tprocessor-main file I have no files for my machine? folder is empty, no options to choose my machinist?
Thatâs because onefinity team did not accept my proposal (mai 2021) yet. Please download it from here
also see README.md
Thank you
I canât figure out how Onefinity works, they have everyone else solve problems, and basically supply all support. Weird to me but maybe I am just too old.
Followup: I created a pull request 2021-04-30 for the fusion 360 post processor in order to give people:
- Step by step instruction on how to install post-processor and machine within fusion
- Added two new customs properties for spindle to let user add a delay and/or a pause when spindle speed change.
- Custom update to enable âuseCircularInterpolationâ by default.
The pull request has not be accepted yet by the onefinity team.
Today I have updated github pull request branch again to keep it up to date and add info for Journeyman.
You can take a look at fusion section of the pull request branch README.md and you can also download files from there too.
You can also take a look at the CHANGELOG.md for more info
Apologies if this has been covered. But is there a version of the PP where at the end of the cycle, the machine simply goes back to the G54 X0,Y0,Z0 rather than the G53/machine home?
Itâs only a tiny niggle but its a pain having to move the spindle back over the workpiece once the operation is done. I can manually alter the code once itâs posted, but if the PP could be changed (or show me where to change it) its removes an extra step.
Thanks in advance
I had the same niggle so I set my return to the centre of the cutting area using the machine setup in fusion360. You can do this f360.
Is there an updated post processor for the X-50?
I think I might have messed something up with when I tried to adjust for the larger axis. Now I am getting the following error when i try to run a simulation.
âMachine tool simulation disabled: The post script has no CAPABILITY_MACHINE_SIMULATIONâ
No itâs the same post processor. If your using the community post-processor, ensure you have the latest release (here). In fusion 360, if youâre using a machine configuration, you fill also find a specific file for the journeyman.
See the README.md
Awesome thanks. I will wipe out the old one and update with this one.
Awesome walkthrough on how to install it. Crystal clear.
Thank you so much for this!!! Your instructions were very clear and made this a breeze!!!
You donât need to select the âmachineâ from the list. Iâve been using Fusion for years and have never had to select a machine. I donât even use your method of post processing. The way I do it is: select your tool path, do a right click on it and select post process. Then, upload the cps file and click post, give it a proper name vs the default 1001. Find the file, change the file extension from .nc to tap or ngc or whatever you need it to be as GRBL is just plain text and the file ext just allows the machine to read the contents. Hope this helps.
Is there a particular reason the Fusion 360 PP outputs a M30 as opposed to M2 at the end of the g code file? In the settings you have the ability to configure âprogram endâ which triggers on M2 but not M30.
I have no idea @cyberreefguru maybe you can enlighten us.
@dalebank - I didnât ask the question. And in fact, I never posted to this thread.
With this Community Version you can select to have M2 instead of M30.
Thanks @blaghislain - it is easy enough to change the PP to output a M2 my concern was is there a nuance between M2 and M30 that needs to be considered before doing so.
@cyberreefguru you are just a wealth of knowledge, we expect you to have all the answers Tom! ![]()
