Dmt2187
(Diehl Townsley)
April 25, 2024, 2:11am
1
I have had two gamepad controllers now that the Z control stops working. Is this a common item and if so, is there a fix or does the game pad controller need to be replace. Running journeyman with buildbotics controller
ianday
September 25, 2025, 1:27am
2
I have this problem too - I ended up using the jogger in the touchscreen. I would be interested if anyone has any further info on this.
Also running Journeyman (version 1.6.4)
Thanks,
Ian
OnefinityCNC
(Onefinity CNC Official ✅)
September 25, 2025, 1:38am
3
You more than likely have the wrong mode selected
This only applies to Onefinity CNC Machines using the BB Buildbotics controller.
[Buildbotics Controller V5 Render]
The correct model is ESM-9013 (pro version will not work) (other model numbers may not move the z axis.)
You will never need to install any drivers or software to use the joypad.
Ensure you are in the right mode with two blue lights on the top.
To use, follow these steps:
Insert batterys into the joypad following the diagram below.
Insert the usb dongle into any of the 4 usb …
ianday
September 25, 2025, 4:58am
4
That solved it - thanks very much.
