Z axis not responding to remote control
My remote control in the Z axis will not move the router up and down. The remote controller will move the X&Y axis perfectly with no issues and I can move the Z axis up and down using the touchpad. It continues to give me an error code for the Z axis saying Caution - The current tool path file would move 4.6mm above axis limit with the current offset - when I home the machine it would not home the Z axis. I reset the Z axis to a piece of wood and drew in V carve a general square to see if possibly the toolpath g-code it might be in the monitor was messing it up. I don’t know if this is making any sense, but this is where I am.
I have the same issue now. I bought a new joypad and it still will not work the z axis. It works fine from the screen, but not the joypad. Has anyone firgured out what the issue is and how to fix it?
immccurley@gmail.com
It was answered above:
Thanks for the quick reply. The information listed did not work, my controller is updated to V1.10 which is newer then the version listed above. I was asking if the issue listed has a fix. I have run a diagnostic on the control and it is functioning correctly. This controller worked for the past 6 months flawlessly, and now it will not move the Z axis. I tried another brand new controller, and it has the same issue. The Z axis works from the screen, and during operation, but will not work with the joypad. I was wondering if there was a fix, maybe I am overlooking. Thanks again for your time and help
Scott
Your issue is 1.1.0/1.1.1/1.1.2 firmware, which has bugs.
Return to 1.0.9 or skip to 1.2 beta
(you will need to flash the SD card to do so).
https://forum.onefinitycnc.com/t/firmware-1-2-beta-new/17612/10
I flashed the SD with 1.2, and configured the control to match my CNC. And it works, thanks again for the help. Super happy
Hello. Had this problem, solved this problem. I’m going to include the advice video that solved my particular glitch at the end here. Spent an incredible amount of time “re-flashing” the chip and trying to update the flash drive for the joystick (already had a higher version!) all to no avail: the lights would go around in circles then stop at the 2 left side sections. Z axis could not be moved. We believe we changed the “modes” (top 2 lit sections on the controller) by unknowingly holding down the on/off button for too long. All it takes is 6-7 seconds and it will change modes and not move something. After seeing this advice vid, I held the button down while the travel drive was in a computer AND THE LIGHTS CHANGED BACK TO THE TOP 2 MODES! If they go a different way than you want, just keep trying and it will cycle around. It now works exactly the way it should. I most sincerely hope this helps someone. BTW, I had no idea what re-flashing meant, but after watching another video, I found I had the correct chip reader to get the job done. I believe I did not need to do that and the simple process of holding down the power button would have solved the problem, but simple choices don’t always come first, do they? Here’s the link: How To Change Modes On The Onefinity Joystick - YouTube
Hey Dale,
it would not have been necessary to search the web and visit Youtube and watch a video. Usually Reading the Fine Manual (or the FAQ in this case) before using a device is enough:
Welcome to the forum!
I just recently had to replace an 2 year old ESM joystick that stopped working with a new one. I made sure to get the correct model but when I try to change the modes on the joystick by holding down the center button it changes my touchscreen from the controller page to a google page. Has anyone else had this happen? Any advice on how to fix this?
I know it’s been a while since that post, but I do have the same issue. My old controller (9013) stopped working and the only model I could find as a replacement was the 9013 PRO. The 9013 is nowhere to be found. Whenever I hit the home button on the game pad to change modes, the only thing that happens is that the the touchscreen changes from controller to a google start page.
But no mode change or whatsoever.
Help would be greatly appreciated, as whenever I connect the game pad to the onefinity via USB-dongle, the game pad launches in a mode where LED 3 & 4 light up and I can’t control the z-axis.
I know that I need to change to the mode where LED 1 & 2 are illuminated.
When I connect the gamepad to my Mac, it launches with LED 1&2 on right away. It seems as if the onefinity controller won’t let me change modes.
I’m on firmware 1.42 on a Woodworker X35.
The joypad replacement is on our site:
Yes, thanks, but I’m located in Germany, if I order the game pad from you guys it will cost me like 80-90 Euros at least.
I need to find a replacement here in Germany or at least the EU…
