I am getting (unfinished) lines on a finished part.
During raster moving on Y axis, using a 1/16β BNEM and stepover of around .005, there are lines not completed to depth(looks like missed a couple X moves), and look to be at equal intervals on the part.
Wondering is it mechanical, or a program issue?
Dan
This can happen if leaning on your table to watch your machine carve. Even a slight deflection of a couple thou would show lines like in your photo. If this isnβt the case, check the coupler on you Z slider to make sure that all screws are tight (including the grub screw).
Can you make another one, but change the orientation 90deg in your design software and mount to a different area of the spoilboard? This could give you some clues to help solve the mystery.
Thanks, I did elbow up to the cut. I guess, the hope is the table is strong enough, but I know its not that strong to not give at all.
Thanks, Dan
