Help with probe
Hi folks,
I recently had a problem with one of my y axis rails jamming up. OF had me run a reconfiguration on it to see if that was causing the problem.
Now when I try to run probe for x,y and z it finishes and goes way past my new set zero. Something is way off. Anyone have this happen or know how to fix it?
Metric vs imperial for bit diameter?
I’m running in metric.
I finally got it figured out.
When I ran the configuration file, it decided it would be a good idea to change some of my settings in the motor 0 stepper calculations. Good thing I took pictures of my settings before running the config file.
Everything seems good now.
Hey Kevin - glad you figured it out. I’m nearly certain you can save the settings as a file, so you have a known good configuration if it ever happens again. It’s just a json file. I think there is a spot in the UI, but I don’t recall where. Once I get my machine running again I can look.
Thanks. That would be helpful.
I will see if I can find it.
