High Torque Step Motor Upgrade Issue
Hi…recently purchased the HT step motors for my Journeyman y-axis. Installed and right side would stall/stop intermittently when using high speed jog. Centering z gantry allowed fast jog without stall. Purchased new wire set from OF, but still had problem. Performed complete maintenance clean and lubrication…no joy. Checked all connections and still no joy. Finally reinstalled original motors and problem went away. Worked with OF support and tried everything they suggested up til reinstall action of old motors. They would like me to send them a detailed video to see if they see something I missed, but that would involve reinstalling HT motors and making the video which I don’t have time to do right now, so was hoping someone on this forum had went down a similar rabbit hole and found a solution? Thanks for any help you can provide!
Did you update the current settings in the axis configuration to match the new motor?
Good morning…OF support said I did not need to make any changes from original motors. Plug and play per them. Do you know of changes I would need to make? Thanks!
I can confirm no changes need to be made, I installed mine with no config changes at all.
Thanks for confirming! Best, Steve
One thing I didn’t bring up was that I’ve also installed the Rowdy Roman riser blocks and the Onefinity stiffy bar. Is there any possibility that my cnc is too heavy and that is causing the issue? Thanks!
