Homing forward causing issues
Occasional when homing it does fine on Z and fine n Y but then moves on X never finds home so just keeps glitching
Forced to turn off then back on, homes fine.
Seems to occur most often when homing from a far distance when nearby the error doesn’t seem to occur?
@Fly_capt - you need to adjust the stall current of the motors for homing. There is a thread about it in the forums (I’ll look for it if you can’t find it). In short, back off the stall current 0.1 amps, then test. If it’s still not working do it again until it works or you reach the limit (0.7 amps I think). I had to back off x and y by 0.2 until they homed reliably.
Hope this helps.
Found the video
