How can it EVER make sense to turn on the router power when a user taps to home z? (Solved, without a tool setter on an elite machine, you MUST separate different tools into separate files)
@Joe_Carrot
i used to do this and also thought it was an issue until one day i thought … maybe it needs time to think. ever since then i hit the cycle start button once and wait - it takes a bit sometimes 10 seconds’ish before it starts, but always does.
i do multiple tool changes with my elite JM and have had mixed results… i get the message to change bits, i do, and get similar results that you have gotten, can’t probe, or when i hit next it wants to probe on its own (never had the router turn on during any of these operations thankfully). pretty sure its the programming within fusion 360 that i was messing with settings as i haven’t had any issues recently.
i have done lots of successful multi-bit cuts using one g-code from fusion 360 - but also several that give similar results you do… i still haven’t really figured out what causes what though… chalking that up to i just don’t know what the hell i’m doing.
that being said - i have started splitting out the gcodes for different bits just so i know it will work. saves a lot of frustration.
j.
Never modified from default. Will check it out.
Thanks
Why did you say this is probablhy the way most people should go?
Is there a reason someone would prefer a 3 wire version over the 2 wire?
Thanks!
Hey Adam,
it depends on whether your CNC controller honors a second state of pressing the tool setter (“over travel”) more than just pressing lightly. There was a discussion about this the other day …here.
The other reason to have more than two wires is if the switch inside is not simply a passive switch, but if it has an active circuitry which allows you to select how it behaves electronically in an input circuit context.
Adam,
When Onefinity releases their tool setter, it’d be a plug and play solution for their Elite systems. No messing around with pull-up resistors, adding additional power supplies, or trying to figure out how to make it work.
The one I went with has 4 or 5 wires (I dont recall). I prefer this, since it was the only one I could track down that wasn’t made in China…
Dan
Three wire models don’t have that functionality, do they?
I have one of similar form factor. It has been working very well, and was chosen for its size and functionality.
I got the big one and mounted it under my table with a piece of scrap 3/4. I got the air blast gate as well, but don’t intend on using it so i took it off
