How do you connect masso to wi-fi. is there a step by step?
I must be missing something basic. I want to connect my onefinity elite to wi-fi, so i can send files to it without using the usb stick.
Have you downloaded “Masso Link” software from the Masso website? That is the only way that I know of to set it up, and must be used to push the file wirelessly.
no i have not. do you have the link?
https://docs.masso.com.au/getting-started-guides/machining-with-masso/wi-fi-connectivity/masso_link
Hit the WiFi icon at the top of the display. This will get the WiFi setup which you can then use Masso Link to send to the controller.
