Trying to figure out many many circuits and what amperage I need for the journeyman pro. Will be running the machine a makita router, the touchscreen, and a shop vac. I’ve seen 2 20 amps is this correct?
Budget a minimum of two, and just dedicate one to your shopvac. If youre just using the makita you won’t have issues in normal use running everything but the shopvac on the same circuit.
I have one 20 amp circuit with router and shopvac on it.
and one 15 amp circuit with controller and screen on it.
Been using it for 3 years, never tripped a breaker or had any other problems.
The router and shopvac are connected with a delay switch so they do not start at the same time.
