How to download awn STL file to carbide create pro?
just upgraded to carbide create pro to start marching 3D images. How do I download a STL file in CC PRO? Do I convert the STL file to another format? which Format and is there a good conversion site to do this?
You should be able to directly import a .stl file into your project then manipulate it (scale/transform), then generate the g-code, using the appropriate post-processor, to carve it on the Onefinity.
