I ordered one at last
finally ordered my journeyman. and most of the upgrades and stuff i wanted. order # 30641 woohoo!
here is the table I am building.
Looks pretty solid to me!
no doubt. About it. the hard part was straightening the pieces as 4x4’s and not noted for being straight lumber
Hey Robert,
how did you straighten them?
i have a jointer and a thickness planer.
It was hard because they were that warped and twisted?
I asked because I was curious if there could be someone here who knows how to / is used to straighten them by hand :slight_smile:
if you mean with a hand plane? you will need a very good plane. I would go to “stumpy nubs” website he has a lot of info on hand planes and what kinds to use for this function. I am way too impatient to take that long to straighten and square up 6 foot 4x4’s by hand
Hey Robert,
I meant I am curious if there could be someone here besides me who knows how to / is used to straighten them by hand :slight_smile:
I have tried to read every post possible but seeing who has what skills I couldn’t begin to guess, but there sure are a lot of computer techies here. i am 68 and have built many things I am also a machinist of sorts I used to build drift trike frames for a company, precision tube bending to 1 tenth of one degree with a cnc bender and machining head tubes and various other parts of the trikes. I am fortunate in that I have a metal cutting lathe and a milling machine.
Hey Robert,
I have read almost everything too :slight_smile: But it’s not always easy to guess, however during the exchange I often try to find out who does what or sometimes people start to tell about it. It is very interesting to hear what people do.
I had a larger workshop longer time ago, but in the last years I was busy in a way that means a lot of work at the screen. In my woodworking shop I have worked for twenty years without any power tools, only hand tools, with very traditional (not to say ancient) methods. But now I have bought some things, including the CNC and hope to have a larger workshop again this year. Here is a picture of one of my jointers :slight_smile: I put a smoothing plane next to it so you can see the size:
Image 1:
Top: ECE Nr. 101 S Jointing plane with chipbreaker, European beech body, European hornbeam sole, 23 5/8" body length, 2 3/8" cutter width, 45° cutting angle
Bottom: ECE Nr. 103 Smoothing plane with chipbreaker, European beech body, European hornbeam sole, 9 1/2" body length, 1 3/4" cutter width, 45° cutting angle
These planes are still made in Germany in the traditional way, since 170 years. However most of the planes I own come from Canada :slight_smile:
Can’t tell from the photos - where does the cord come out? Or do the batteries just slide in the base? :laughing: :smiley:
Hey Robert,
didn’t know this one, thanks for the tip
This works quite well if you see it as a kind of meditation :slight_smile:
This is very interesting. Did you weld the tubes too?
Then yes, I would consider you as fortunate :slight_smile:
I can weld but it aint pretty. my son is the welder. I’m a problem solver. i will think of ways to get it done. lol
It’s powered by Green energy, so long as you don’t release too much methane while pushing.
they run on unleaded porridge :laughing:
thank you for all your help I got my notice of a label created today so I know my JM is on its way soon. I have been learning the software and i think i saved my first project so that i can cut it when i get the machine all set up and running. Again, thanks for all your help I hope be of help to others as well sometime.
Robert
