Gen 2 Redline HMI. I’ve set it to imperial in the config settings, AND tapped the metric / imperial button on the main screen to set it to imperial. If I boot up the machine first and wait for it to load up before turning on the VFD (to avoid the error 14 code) the machine is always switched back to metric. Is this a known bug that will be fixed? If I do it the other way it loads to imperial, but then I have to hit the stop button on the DRO for the spindle to clear the error 14. So either way I’m having to tap an extra button unnecessarily.
My machine acts the same way
