Installation pics of MASSO Pendant
After receiving my MASSO Pendant today, I panicked at the lack of a port on the back of the controller case. There were no instructions with it. Eventually I realized that it needs to plug into the controller assembly inside the case. I removed the DB connector case (doesn’t fit) and moved the strain relief lower on the cable to allow it to be used with an existing machine screw mount in the case. I simply removed one of the screws and replaced it with a M3 socket head screw. I screwed the DB connector to the controller and, for overkill, attached the chord to the case with a zip tie adhesive retainer block.
This pendant is super awesome! Well built and so convenient!
I love my pendant as well. It’s a shame they didn’t adjust the orientation of the controller to allow the pendant to attach as is. Maybe it was an afterthought.
Agreed. I could have waited, ordered a DB extender and internally jumped from the controller to the case. Probably the sexier thing to do, but no reason to do so now that it’s working.
I did the same…minus the zip tie retainer, but now seeing yours, think its a good idea and will do the same. No sure why they would build a controller box with connection for their own pendant that doesn’t fit as manufactured with the cable end casing left on it----fail on their part. Pendant works great and comes in very handy–after using it I actually prefer it over the gamepad for positioning the tool bit. Don’t know how many times I forgot to change the speed on the gamepad or used the wrong toggle by mistake.
I just got my cnc and I am in process of putting the finial touches (dust collector hose routing, traming etc) but ahead of my delivery, I knew I wanted the pendant like many others have raved about. But seeing the issue with install, I went searching online for a a solution and I found one, that fits perfectly and still allows the door to close.
Odd. I had no issue with mine. Cable routes through the back hole along with the others.
Mine routes though the back along with the others too, I was referring to the beige adapter. I thought it was a cool, clean solution to the unfortunate design by masso with their connector not able to be plugged in with door closed. The masso pendant is really crazy great, glad I picked one up.
Can you provide a link to where you acquired that adapter? I just installed mine but did not like the fact that I had to take off the housing. I did do the zip tie strain relief method…
I absolutely can, I was planning on making a separate post about it and taking a couple extra pictures, because along with the adapter you need one other part which is a “female to female” changer as the right angle adapter ends in pins like the masso pendant, so you need that part as well.
The company makes lots of cables in all different lengths, the one I got was a 1ft cable, If I had to do it again, I might get the 2.5 foot, this would allow the cable (and its end) to route all the way out of the masso and out the back. The one I got has the “connection” between the adapter and the masso, internal, behind the screen. If there was ever a reason you wanted to unplug it, you would have to open the screen case. If you went with the longer one, that wouldn’t be necessary. But the shorter one gives a cleaner look with just the black masso pendant cord coming out of the masso display back… you will have to decide which is better for your needs.
Either way, the “must” is the “exit right” connector (as they make an “exit left” also, which would send the “L” in the wrong direction.
Lastly I removed the terminal screws from the adapter too, as they would be in the way and not needed as the edge of the case cover keeps the connector in place.
Similarly to the above I added strain relief inside for the adapter connection with zip tie.
https://www.l-com.com/d-sub-deluxe-molded-d-sub-cable-db15-male-right-angle-exit-1-male-10-ft
https://www.l-com.com/d-sub-slimline-gender-changer-db15-female-female
thank you for posting this I got one on order now. chip chip chipping away at my bank account lol.There goes another 40 bucks.make that 60 wow
Strange that my order was 54823 and i got it Monday the 28th of April? But I am not going to complain. ps: Mr krag I got my Masso pendant from pwncnc yesterday. then i proceeded to find out how to install it on the masso. Weird that masso makes a pendant especially for their own controller that does not fit in their controller without major modifications and when you do it, it looks like shit that any craftsman would be ashamed to claim as their idea of engineering. The best thing I could find to remedy this was an adapter from a company called L COM it fits inside the Masso controller and looks neat and tidy and more importantly does not require you to disassemble and exposed the wiring. here are the links to the fix that Rizzo Brian found . Profile - Rizzo - Onefinity CNC Forum Be sure to read the entire post cause there are actually two pieces you need to make this a better installation than what Masso’s sloppy engineers designed.
I just 3D printed a simple wire cover and called it done. I’m including the STL file here for anyone who wants it.
DB-15 Cover for Masso Pendant.stl (98.0 KB)
Thank you for including the stl. I will print that out as it will solve the issue with the exposed wires.
I was thinking the same thing, thanks for saving me the time!
It certainly is a less expensive solution than I was touting.
I wasted a day trying to make a full casing to replace the original. Started out printing small parts to test the fits and hole alignments. To get the wires to fit, the casing kept getting bigger (longer). I ended up with something that covered up the ribbon port below the MPG port, so I nuked the idea.
Technically it wasn’t a wasted day … I figured out what didn’t work. :slight_smile:
At the very least, it keeps me busy while I wait for my spindle. :face_with_tongue:
here is an update. I got the parts in today and of course I screwed up once again. the exit 1 is the way to go but I got the exit 2 because i ordered the 2.5 foot cable because i wanted the plug to be outside the masso controller so that i could simply u plug it If i ever wanted to. well it stil works as you can se by thee photos i am including. who ever said the cord was going the wrong way was right. how ever it can stil work as you can see. By the way it was really plug and play. except for the emergency stop button on the pendant but that is a simple fix as you can find elsewhere on the forum.
so as you can see it still works. tidy and secure. about 27 dollars.
It was me woodpecker, I looked at this cord and can see it was going the wrong way. I make this so I know.
you sure were right but as you can see it works so I don’t mind.
