Introducing the new Onefinity ELITE Series, Powered by MASSO
thanks - but I would like to have the 80mm as “additional” - not as one or the other please. :slight_smile:
Great about tool setter - any idea about price?
Good morning @OnefinityCNC. The Elite Series hits the sweet spot. I ordered a this morning :smile_cat: …
Would it be possible to get engineering drawings for the y-rails mounting pattern, hole dimensions, and ideally the entire machine? I am also trying to figure out where the center of the 80 mm spindle lands when it is as far towards the front as possible (for vertical work holding and machining).
Extra bonus points if you can make this available as some kind of file that I can import into Fusion 360 for fitting everything together.
One more thing, will the Onefinity Masso controller work with Masso accessories, in particular the relay module and pendant?
Thanks!
tech drawings will come at some point.
Yes, it works with anything masso, There are already two relays connected, one for vac, one for router.
Fantastic! Thanks for the quick reply.
I wonder if Onefinity will sell a tool changer or if this is something that we will have to manage 3rd-party
OnefinityCNCOnefinity SupportLeader
7h
  • Put in a 80mm Spindle on the journeyman to spin 1/2 shank bits (no matter what you’d do, you’d need that).
  • Buy a different brand to gain an ATC. We don’t have one.
This was in another post 7 hours ago.
Does the new z20 slider when set up for a 65mm spindle have ample clearance on the servo and mount?
yes, a spindle will clear the stepper motor on the Z-20 with a 65mm mount.
Win OnefinityCNC be selling the MASSO MPG Pendant, or will that have to be sourced from them directly?
Will you still be offering the regular series or will that be transitioned out?
The regular series is a fantastic value and won’t be going anywhere.
that is good to know.
The description says Imust use the 15" screen on the Elite series. Really? I can’t use the 22" touchscreen I have for my X 35?
Yes, because the screen IS the controller. It’s an all in one unit.
Will the new Elite line have a post processor for Fusion 360?
I have been using a Masso G3 with my Woodworker and F360 for quite a while now - there is a PP available at Autodesk.
I did see it but wasn’t sure the generic mill version was working well with the Onefinity machines. Good to know someone is using it successfully. I really prefer staying in Fusion 360 if possible. Thank you.
I’m super excited for this… already got my order in :slight_smile:
Does MASSO Link allow for remote E-Stop?
I couldn’t find anything definitive on being able to execute some of the custom inputs remotely, but I found a list of programmable inputs. The phone app looks incredibly limited, but I believe the windows app is closer to full duplication.
I’m of course only going off what I can find on Google, so if in the future we determine it to be false, like you I don’t have mine in hand to answer positivity.
https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/list-of-configurable-inputs
