JourneyMan Z Axis Plunges Too Deep above F360 Lenght (solved, wrong z config set)
My OnFinity JourneyMan Z Axis Drill Bits Goes Deeper that Fustin 360 Depth Setting for Bore Hole. The Bore Hole is 3.9 , the Workstock is 12mm, yet the Drill Bit almost triples the Depth of Cut on the Z axis.
Note , my Router and Drill Bit are New and are inserted very tight, the Bit does not shift positions.
1001 SQ X.nc (2.3 KB)
I did test file with both Bore and Contour, the issue still happens.
Sounds like you have the wrong z slider configured:
Problem is Solved, Wrong Z Slider was setup previously.
