I am having mounting issues lots of wobble. I need STL so i can make a change in the mount. Laser build has quality issues. lasergap.jpg - Google Drive big gap causing lots of movement rocking back and forth. found i think the issue backoflaser.jpg - Google Drive Nut sticking out not flush. best way to fix? hot knife make room for the nut? (putting a dip in the mount to make room for the nut) or zip tie around laser to prevent movement? not big on that idea or this disassemble laser? to rethread the nut
issue Fixed: had to reseat the nut so it would be flush. wire retainer 2 screws then 4 screws in the back of the laser. then you have access to the screws that need adjusted
