Kreg 44x64-in table & Journeyman X-50 & MDF
What do you mean when you say you, flipped the Y rails to limit the space the Dustboot would eat into the size of the table ?
Most dust boots have the hose attachment to the front of the spindle/router which sticks further to the front of the machine. The default setup is to have the stepper motors in the back which stick out from the ends of the rails, if you flip the rails around and have the stepper motors in the front the dust boot and the stepper motors are closer to being in line with each other vs the dust boot overhanging the end of the table.
Hey Jim,
you can mount any of the Onefinity’s rails with the motor pointing in the other direction, e.g. X rail with motor on the left (instead of right), or Y rails with motors pointing towards front (instead of to the rear). If you do this, you have to check the option “reverse” on the corresponding MOTOR page under “Motion”.
Here is a video from the manufacturer:
So if you want to save space, you could flip Y rails so the Y motors point towards the front, since this space, that is in front of the machine’s dimensions, is required for the dust boot anyway.
Here you can see that the dust boots protrude beyond the dimension of the machine:
(What is the Best Dust Boot for the Onefinity? )
[/quote]
Just in case you build an enclosure or a flippable table top, you can also reserve some more space in case you retrofit other motors later. Motors with encoders (closed-loop) or a brake on the rear can be much longer.
Essentially what Wayward and Aiph5u have said. If you set it up like normal with steppers in the back, that is wasted space in the back that would overhang a table, and then the dustboot sticks out in the front. By reversing the y-rails, that overhang is now in the front and the dustboot occupies that same wasted space on a table top. Not sure of my total savings when trying to do an enclosure, but I am sure it at least 2-3" of overall footprint from front to rear.
