Not exactly new to this. But ran into a new problem . That has stumped me… using a 7wpro jtech laser. W/ air assist. Cutting 5MM plywood.
Panel 1 cuts just fine. Panel 2 little less then fine but can push the pieces out. Panel 3 not so much having to cut back side out a little. 4 is worse then 3 so on and so on. I have 3/4 spacers under project. Why is it doing this? Three things i can think of. One would be power strip is not of the highest quality. But doesnt get hot… two shop vac and air assist pump are in the same cabinet. To reduce noise. It does get hot in there . The shopvac exhaust exits outside though. With fresh air coming back in. Or the jtech laser is having issues with the length of time being on. Idk?
