I’m making a Laser Material Test Cards for my JTech 24-44-64 Laser.
Can someone confirm my thinking:
In the BB Manual “Cutting rates are set in GCode…Motor Max Velocity --is set in the Motors Entry Box…Axis will not move at a rate greater than this value…even if feed rate in GCode is Greater”.
My Max Motor Velocity rate is factory set at 393.7008 IPM
So, on my laser test card anything faster than 394 IPM would technically be the same? (seems that way)
How fast is a good speed for a 64W Laser?
Thanks, any information greatly appreciated.
(squares you see are the only ones entered so far.)
Woodworker 50X VCarve Pro 11 with Vectric Laser add-on
Thanks Bill
